- Clearance - While Supplies LastVOLT® Lucid Brass Spotlight (Bronze) - CLEARANCE
Regular Price $69.97 As low as $59.97
Solid brass lamp-ready fixture specially designed for extra-powerful light output.
Designed to primarily be used with our 9W LED MR16 bulb (70W Halogen Replacement), this fixture is specially designed for high lumen output. The recommended bulb features a special thermal foldback design which will help dissipate heat by gradually dimming if needed. Features toolless adjustability for precision light control.
Available while supplies last.
Learn More - Clearance - While Supplies LastVOLT® Locket Mini Brass Hanging Light (Bronze) - CLEARANCE
Regular Price $82.94 As low as $62.94
Beautiful mini brass hanging light with chain. Perfect for lanais, decks, patios, gardens and more.
Designed to produce compelling illumination from above. Can be hung from limbs, pergolas, gazebos or any overhang. The illumination is a combination of a circular spot directly beneath the fixture and a decorative pattern surrounding the light.
Learn More - Clearance - While Supplies LastVOLT® Recessed Soffit Downlight (Aluminum White) - CLEARANCE
Regular Price $39.97 As low as $29.97
Adjustable, recessed downlight - designed for downlighting applications in soffits or ceilings.
Adjustable in any direction for precision aiming of light output. Features a quick connect plug for easy installation and quick daisy chaining. Requires 120V junction box (included) - not for use with 12V transformers. Designed for use with 12V LED MR16 bulbs.
Learn More - Clearance - While Supplies LastVOLT® Cast Brass Up/Down Integrated LED Deck Light (White) - CLEARANCERegular Price $75.94 As low as $45.94
Introducing the revolutionary integrated LED Up/Down LED deck light (Titanium White Finish)
The Up/Down Deck Light is a distinctive and elegant cast brass fixture that offers the benefits of a compact deck light along with the beauty and functionality of an up/down sconce. This fixture is ideal for posts on gazebos and arbors, and for wall mounting along steps, stairs and entryways. The unit is also ideal for mounting on columns and pillars.
Learn More - Out of stockOut of stockRegular Price $324.97 Special Price $199.97
VOLT®'s new line of 120V color-changing integrated LED floodlights - powerful, widespread illumination with vivid colors.
120V RGBW LED floodlight with powerful, widespread light output and vivid color-changing capabilities. Uses standard 3-prong GFCI plug. Designed for easy relocation - ideal for temporary placement for special occasions or other outdoor events. Integrated LED with IR remote control for dimming and color modes.
Learn More - SaleRegular Price $40.97 Special Price $32.97
Direct replacements for halogen PAR36 bulbs with similar light levels using only a fraction of the power consumption.
Fully encapsulated to keep moisture out and matching 2700K color temperatures make these low-voltage bulbs great alternatives to typical halogen PAR36s. Our LED bulbs are built using Cree® LEDs.
Lifetime Warranty
Learn More - SaleRegular Price $36.97 Special Price $32.97
Fully encapsulated to keep moisture out and matching 3000K color temperatures make these low-voltage bulbs great alternatives to typical halogen PAR36s. Our LED bulbs are built using Cree® LEDs.
Lifetime Warranty
Learn More - Clearance - While Supplies LastTHOR Omnidirectional LED G4 Bi-Pin Bulb
Regular Price $15.97 As low as $11.98
Compact, lightweight LED bi-pin bulb designed specifically for low voltage landscape lighting.
Choose from 1.5W to 5W and warm white (2700K) or soft white (3000K) Thor LED G4 bi-pin bulbs. These versatile bulbs work with a variety of VOLT® fixtures—path lights, deck lights, step lights, hardscape lights, and more! Plus, the 360° omnidirectional design ensures even light distribution, eliminating dark spots.
Available while supplies last. Learn More - Clearance - While Supplies LastTHOR Maestro Omnidirectional LED G4 Bi-Pin Bulb
Regular Price $20.97 As low as $15.73
A high CRI (98) compact, lightweight LED bi-pin bulb designed specifically for low voltage landscape lighting.
With a high CRI (Color Rendering Index) of 98, this Maestro G4 bi-pin bulb ensures vibrant color accuracy, making every element of your outdoor space appear rich and natural. Choose from 2W to 5W and warm white (2700K) or soft white (3000K) These versatile bulbs work with a variety of VOLT® fixtures—path lights, deck lights, step lights, hardscape lights, and more! Plus, the 360° omnidirectional design ensures even light distribution, eliminating dark spots.
Available while supplies last. Learn More - Clearance - While Supplies LastTHOR Single Source LED MR16 Bulb
Regular Price $13.97 As low as $10.48
Single source LED MR16 bulb designed specifically for low voltage landscape lighting.
Choose from 2W to 7W, warm white (2700K) or soft white (3000K), and 15° to 110° beam angle Thor single source LED MR16 bulbs. These versatile bulbs work with a variety of VOLT® fixtures—spotlights, well and in-grade lights, and underwater lights. Plus, the single source LED produces much crisper shadows for a dramatic effect.
Available while supplies last. Learn More - Clearance - While Supplies LastTHOR Maestro Single Source LED MR16 Bulb
A high CRI (98) single source LED MR16 bulb designed specifically for low voltage landscape lighting.
With a high CRI (Color Rendering Index) of 98, this Maestro MR16 bulb ensures vibrant color accuracy, making every element of your outdoor space appear rich and natural. Choose from 4W to 7W, warm white (2700K) or soft white (3000K), and 24° to 80° beam angle Thor single source LED MR16 bulbs. These versatile bulbs work with a variety of VOLT® fixtures—spotlights, well and in-grade lights, and underwater lights.
Available while supplies last. Learn More - Clearance - While Supplies LastTHOR Maestro 5W Foliage Enhancing LED MR16 Bulb (4150K)
Regular Price $28.97 As low as $21.73
Foliage color enhancing LED bulb designed specifically to enhance the natural green of plants & trees.
Using its “cool green” color temperature (4150K), the Foliage Enhancing LED MR16 bulb is designed to intensify the natural green colors of plants and trees in your outdoor space. Choose between 36° or 60° beam angles to perfectly highlight prized greenery. Rated for outdoor use in damp locations and thermal protection for use in sealed landscape lighting fixtures.
Learn More - Clearance - While Supplies LastVOLT® RGBW 15W Integrated LED Flood Light with Yoke Mount (Aluminum Bronze) - CLEARANCE
Regular Price $219.97 As low as $119.97
VOLT®'s new line of color-changing integrated LED floodlights - powerful, widespread illumination with vivid colors.
12V RGBW LED floodlight with powerful, widespread light output and vivid color-changing capabilities. Made from die-cast aluminum with super-durable powder coating. Features an integrated LED with IR remote control included for dimming and color modes.
Learn More
