Why Use Outdoor Underwater Lights?
Whether you have a backyard pond, a decorative fountain, or a water feature along a patio, underwater lighting completely changes how your outdoor space looks and feels after dark. Here are the three biggest reasons homeowners and landscape professionals choose submersible lights.
Boost Aesthetic Appeal
Underwater lights turn ordinary ponds and fountains into captivating focal points. The combination of water and light creates a resort-like atmosphere, adding elegance, depth, and brilliant accents that elevate both backyard beauty and curb appeal.
Improve Safety and Visibility
Like all landscape lighting, underwater fixtures improve general safety around your property. Illuminating pond edges and water depths helps prevent accidents and makes your outdoor spaces safer for gatherings, entertaining, and everyday use.
Versatile Design Options
With an IP68 waterproof rating, these fixtures can be fully submerged without any issues. Choose clean white light or opt for RGBW color-changing underwater lights to dial in different moods and effects throughout the seasons.
Types of Low Voltage Underwater Lights
VOLT® offers two types of underwater lights to fit different project needs and budgets. Understanding the difference will help you choose the right fixture from the start.
Lamp-Ready Lights
These fixtures use replaceable bulbs, giving you full flexibility to customize brightness, color temperature, and beam spread. If a bulb ever burns out, you can swap it in seconds with no need to replace the entire fixture.
Integrated LED Lights
These lights have built-in LEDs that deliver brighter, more energy-efficient output with long-lasting performance. No bulb changes required. The LED module is engineered right into the fixture for a cleaner, more reliable setup.
How to Install Pond and Fountain Lights
Getting your underwater lights positioned correctly from the start makes a huge difference in the final effect. A little planning before installation saves time and produces a far more polished result.
- 1 Install during construction or a cleaning drain. The easiest time to place pond lights is when the pond is empty, either during initial construction or during a scheduled drainage for cleaning. This lets you position fixtures without dealing with water depth or limited visibility.
- 2 Angle lights across the water, facing away from the viewer. For the best effect, aim lights across the water toward focal points like waterfalls, rocks, or aquatic plants. Position them so the beam faces away from the main viewing area to highlight features without glare shining back at you.
Seasonal Maintenance for Underwater Lighting
Proper maintenance keeps your underwater fixtures performing and looking their best year-round. A little routine attention goes a long way in preserving light output and extending fixture life.
Lens Cleaning Ongoing
Develop a routine to clean fixture lenses regularly. A dirty or algae-coated lens significantly reduces brightness and color output. In pond environments especially, watch for algae or dirt buildup that acts as a barrier and dims the light. Also remove any debris that collects around the fixture, as trapped debris can retain heat and shorten LED life.
Position Adjustments Seasonal
Revisit your light placement throughout the year. As seasons change, plants and vegetation grow and water levels can rise, both of which can block or redirect light beams. Periodically adjusting angles or repositioning fixtures ensures your key focal points, like waterfalls or rock formations, stay properly illuminated all year long.
