Color-Changing Landscape Lighting
June 18, 2020
Converting your home for the holidays with landscape lighting.
Landscape lighting for the holidays 1
Landscape lighting for the holidays 3
Landscape lighting for the holidays 4
Installing traditional holiday lighting can be extremely time-consuming - hours can be spent unpacking, untangling and setting up. When the holiday is over, you also have to remove and repack all of the decorations. Not only is this process time-consuming, it is also dangerous when involving ladders and working on rooftops.
A simple way to convert your home for the holidays is to use color-coordinated landscape lighting. Color-changing LED bulbs and color-changing LED lights offer a permanent outdoor lighting solution for holidays, special events and year-round use.
Benefits of Color-Changing LED Landscape Lighting
  • True-to-color LEDs produce powerful, vibrant colors
  • Multiple color combinations including traditional white for year-round use – not just for use during holidays
  • Convenient remote control capabilities available – quick & easy set up
  • Variety of fixtures available for any lighting application
  • Safe, energy-efficient low-voltage (12V)
  • Lifetime Warranty on all VOLT® RGBCW LED Bulbs & RGBW LED Brass Lights
How to Use Color-Changing LED Landscape Lights
When using color-changing landscape lights for holidays specifically, colors should ideally be applied in an alternating manner.
For a Halloween themed design, you can alternate colors between green, purple and/or orange. For a Christmas themed designed, alternate between green and red. Patriotic colors like red, white and blue can also be used for a variety of holidays such as July 4th, Memorial Day or Flag Day.
If using VOLT®’s RGBCW LED bulbs, you can conveniently set up permanent lighting zones that allow for quick & easy adjustments for any occasion.
There is no better way to prepare for holidays or special events than having eye-catching, colorful illumination displayed on your home.
Color-changing LED landscape lights provides a variety of vibrant colors and offers efficiency, durability, and safety. Flexibility with applications and ease of control make them the ideal choice for homeowners looking for a permanent holiday lighting solution that also looks beautiful year round with traditional white light options.
As low as $154.99
Durable cast brass (thick/heavy). Dimmable with adjustable color & CCT (remote control required). Adjustable glare-guard & knuckle for precision aiming.
RGBW RGBW
As low as $119.99
Durable cast brass (thick/heavy). Dimmable & color-changing (remote control required). Adjustable glare-guard & knuckle for precision aiming.
RGBW RGBW
As low as $209.99
Provides powerful, wide light output. Durable, cast brass construction (thick/heavy). Adjustable yoke mount for aiming light output.
RGBW RGBW
As low as $149.99
Durable cast brass (thick/heavy). Dimmable & color-changing (remote control required). Fully-submersible design (IP68 rated).
RGBW RGBW
A step by step guide to set up color changing LED landscaping lights.
How to Set Up VOLT® Color-Changing LED Landscape Lighting Bulbs
Learn how to set up VOLT®'s color-changing LED bulbs. Easily change colors, color temperature, brightness and create multiple lighting zones.
An essential guide to preparing your Christmas lights for the winter weather.
How to Weatherproof Christmas Lights
Setting up holiday lights comes with plenty of challenges. Learn how you can weatherproof your outdoor Christmas lights.
Easy Steps to Prepare Your Landscape Lighting Fixtures for Winter
Follow these easy steps to ensure your property and landscape lighting fixtures are ready for the winter months.
Decorating with Solar Christmas Lights
Tired of unraveling extension cords and dreading your electric bill at the end of December? Switch to VOLT®'s solar-powered holiday lights.
