Introducing VOLT Essentials. Outdoor Lighting Made Affordable! | SHOP NOW
How to Install Landscape Lighting: Step-by-Step Guide
June 5, 2020
An easy, step by step guide to installing your low voltage landscape lighting.
After you’ve learned the basics of landscape lighting and how to create a plan for your system, you can now think about how to install landscape lighting. Installing low voltage landscape lighting is an easy do-it-yourself project that most homeowners can complete.
DIY landscape lighting with low voltage (12V) is a safe and easy project. These landscape lights carry little risk of electrical shock, and you can bury the wires in shallow trenches. However, if you are using line voltage (120V) lighting, it must be installed by a licensed electrician. Before starting, please refer to the National Electrical Code® and your local electrical codes.
Also, gather any tools you might require for the job – most importantly, a set of wire strippers and a shovel or trenching tool. Additional tools may be required, depending on the needs of your project.
Tools
  • Wire stripper
  • Shovel or trenching tool
  • Stake installer
Instructions
Step 1: Install landscape lighting
Step 1: Physically mark any existing cable or irrigation lines, so that they aren’t damaged during the low voltage landscape lighting installation.
Step 2: Install landscape lighting
Step 2: Unpack and assemble your landscape lighting fixtures. Take everything out of its box, then install bulbs in any lamp-ready fixtures, and attach mounts. There are many ways to mount fixtures, but most fall under one of these three categories. Stake mounting is where a stake is attached to the fixture and then place directly into the ground. Surface mounting is used when a fixture must be attached to a hard surface and it usually requires a power drill. In-ground mounting is when a fixture is mounted directly into the earth, so having a spade, shovel or post hole digger is a big help.
Step 3: Install landscape lighting
Step 3: Clear a path for your wire runs and place your fixtures based on the project map you created during planning.
Step 4: Install landscape lighting
Step 4: Mount your low voltage transformer. When choosing a location for your transformer, it’s important to keep a few things in mind. Transformers must have 1 foot of clearance in every direction, be at least 30 feet away from water features and be on a surface that can withstand the heat it produces. Learn more: How to Install a Low Voltage Transformer
Step 5: Install landscape lighting
Step 5: Lay out and dig your trenches for your main wire runs. Most people use a shovel or spade for trenching, but more specialized tools are also available. The exact depth of the trenches is determined by your local codes, but low voltage cable is typically buried at least 6 inches deep. Once dug, place the wires in your trenches and cover them completely with dirt. Be sure to leave at least 5 feet of unburied wire at each end, so that you have room for adjustments lat
Step 6: Install landscape lighting
Step 6: Begin connecting your system. For a simple connection process, use a clamp connect transformer, which uses levers instead of the screw mechanism to clamp to the wires. Start by connecting your transformer to your main runs. This is done by placing one strand of wire in the com terminal and the other in a terminal marked either 12 volt or 15 volt. The 12 volt tap is for shorter wire runs with fewer fixtures while the 15 volt tap is for longer runs that draw more power. Wire exiting the transformer should be protected with conduit until it reaches the ground.
Step 7: Install landscape lighting
Step 7: Connect fixtures by splicing their lead wires to your main runs. The most common method is to use twist-on style connectors. These connections are made by stripping the last half inch of wire at each end, then twisting them together in a clockwise direction. Then insert the connection into the cap and twist clockwise until the wire begins to spin with the cap. Another option is to use clamp connect junctions. To use these, simply invert the stripped wire ends into the terminal, push down the lever and close the housing. This protects the connection from moisture and corrosion. If you have a cluster of fixtures, you may want to use a hub (pictured here). Hubs allow you to easily connect multiple fixtures in a single location. Hubs can either be stake-mounted above the ground or buried underground.
Step 8: Install landscape lighting
Step 8: Once all of your connections are made, you can test your system. Turn on your transformer and then walk around your property to ensure that every fixture is lit. If one is out, it may be that you have a bad connection on your system.
Step 9: Install landscape lighting
Step 9: If all your fixtures are properly functioning, you can now begin the adjustment phase of your installation. Wait until nighttime before starting adjustment; that way you can clearly see the lighting effects created by each fixture. Now walk your property again and make sure each light is aimed at the desired feature in your landscape. You’ll also want to keep an eye out for glare coming from your fixtures. Glare can be remedied by adjusting the angle of the fixture or the position of its glare guard.
Step 10: Install landscape lighting
Step 10: Finish your project by burying any remaining wires and programming the timer on your transformer.
Congratulations – you have now completed your installation! If you encountered any issues or have additional questions about how to install landscape lighting, the experts at VOLT® are available 7 days a week to help; call us at (813) 978-3700.
Better Sale
Bronze
Special Price $230.99 Regular Price $329.99
Complete Landscape Lighting Kit Includes: (4) MR11 Brass Spotlights, (2) 24" Brass Path Lights, (1) 100W Transformer LED bulbs, 50ft of cable & wire connectors.
Better Sale
Bronze
Special Price $181.99 Regular Price $259.99
Path Light Expansion Kit Includes: (4) 24" Brass Path Lights, LED bulbs, 50ft of cable & wire connectors.
Better Sale
Bronze
Special Price $139.99 Regular Price $199.99
Spotlight Expansion Kit Includes: (4) MR11 Brass Spotlights, LED bulbs, 50ft of cable & wire connectors.
As low as $999.99
Complete Kit Includes: (6) MR16 Fat Boy Brass Spotlights, (4) 24" Max Spread Brass Path Lights, (1) 150W Transformer, LED bulbs, 100ft of cable & wire connectors.
Understanding the basics of choosing the best outdoor lighting for your yard and living space.
How to Choose the Best Landscape Lighting for Your Home & Yard
Low voltage landscape lighting is a great DIY project. Before you get started, learn the basics of outdoor lighting and common fixture types.
The ways landscape lighting can improve home security
How Landscape Lighting Increases Home Security
A well-lit property has fewer hiding spots for burglars. Learn how to us landscape lighting as a form of home security.
Learn how to make a plan for a low voltage landscape lighting system, along with tips to ensure a successful installation.
