In this article, you will learn how to set up the VOLT OHMâ„¢ outdoor audio system. Use this system to bring your yard and other outdoor spaces to life. Designed with the DIYer in mind, VOLT OHMâ„¢ features hassle-free installation. No electrician is needed, and no cutting or splicing is required. The direct plug-and-play connections reduce installation time to less than an hour. This system can be installed in five simple steps.
Step 1
Set Up the Amplifier on a Flat Surface
The Bluetooth amplifier is powered by high-quality chipsets for consistent connection, superior range, and effortless connection. Place your amplifier in a weather protected space. It is important to keep the amplifier in a dry area to ensure performance and longevity.
VOLT OHMâ„¢ Bluetooth amplifier placed on flat surface
Step 2
Lay Out the Main Cable Where You Want Sound Coverage
Proper cable placement is crucial because it determines the location of your speakers. The T-connectors are 12 feet apart to help you effectively position your speakers. Outdoor stereo separation is best at about 8 to 10 feet apart. If you want to expand your system in the future, a well planned layout will simplify this process.
Laying out the VOLT OHMâ„¢ main cable for outdoor speaker placement
Step 3
Install Outdoor Speakers and Adjust Angles
It is important to plan your layout and make a mark where each speaker will be placed. A ground stake is included for mounting. The speaker arm adjusts 150 degrees and locks securely in place, minimizing sound spillover into unwanted areas. If you are looking to expand, the system can scale up to eight speakers.
Installing and angling VOLT OHMâ„¢ outdoor speakers using the ground stake
Step 4
Install the Subwoofer in the Ground or on a Hard Surface
The subwoofer design supports installation on the ground, surface, deck, or buried in-ground to fit any outdoor landscape environment. The subwoofer has a 6-foot prewired cable. This can be plugged into any T connector. Positioning it near a wall will deliver deeper bass.
Installing the VOLT OHMâ„¢ outdoor subwoofer in the ground
Step 5
Connect the Amplifier and Audio Devices
The VOLT OHMâ„¢ system uses Bluetooth® V5.3, which provides superior range, a more stable connection, and faster, smarter switching between paired devices. There are multiple input options so you can connect to various devices. It also supports direct streaming from platforms like Spotify, Pandora, and Apple Music. Use any application of your preference!
Connecting the VOLT OHMâ„¢ amplifier to a smartphone for Bluetooth audio streaming
Congratulations, Your VOLT OHMâ„¢ Audio System Is Ready!
You have successfully set up your VOLT OHMâ„¢ Audio System. If you have any additional questions, please give us a call at (813) 978-3700 or email us at customersupport@voltlighting.com.
