Spring Solar Light Sale – 10% OFF! | SHOP NOW
Avoid Landscape Lighting Design Mistakes
May 12, 2020
Landscape lighting design can be a simple do-it-yourself project for most homeowners – but to the trained eye, there are some pitfalls to avoid. This article points out some common mistakes – and how to correct them.
Using the wrong fixture type for the application – Be careful to match your fixture type to the application. For example, use spotlights to accent individual objects or regions. Use floodlights to illuminate broad areas of walls or garden beds. Use well lights to hide the lights in turf areas or hardscapes. If you have a question on what type of fixtures to use, call our Customer Support line: 813-978-3700.
Blinding the viewer – Sounds extreme, but surprisingly this is one of the most common mistakes in landscape lighting. Ideally, whenever you install a fixture, it should not be positioned in a way that exposes the light source to the eye; that’s called direct glare. Direct glare causes visual discomfort and can obscure vision to the extent that the viewer is unable to see clearly for a period of time. To avoid direct glare, use spotlights and flood lights with glare shields and position the fixture so the shield effectively blocks the light source from viewers’ eyes. VOLT® fixtures are designed to minimize direct glare, but it is up to you, the designer to position them with this in mind.
Creating an airport runway – Have you ever seen lights along a path that remind you of an airport runway, lined up perfectly, one after another? This is not the effect we want. Instead, position lights in a zig zag pattern, alternating from one side of the path to the other. And, for curving paths, position lights in a way that follows the curve.
Using path lights that are the wrong size or style for the path – A short or narrow path should have smaller path lights. Also to consider, the architectural style of nearby structures. For modern styles, use path lights with classic or simple appearances. For more decorative structures, use the decorative style fixtures.
Unbalanced Lighting – The principal of balance refers to creating a harmonious relationship between two adjacent regions. For example, consider the left and right sides of a front yard as viewed from the road. Illumination on the left side should look good in relation to the illumination on the right side. That’s not to say they need to appear identical, but certain lighting themes should match – such as all trees lit on the left should be lit in the same way on the right. This principle of balance also relates to symmetry – such as using the same lighting technique on all columns along the front of the house.
Over-Illumination – To capture the essence of a nighttime landscape, lighting should be adjusted to as low a level as possible. The light of a full moon has a light level of only 0.01 foot candles – we all love that look. Typical path lights project a level that is 10 times the foot candles of moonlight. A typical spotlight projects over 100 times that level. The point being to keep light levels as low as possible while still satisfying the safety, security, and beauty goals of the design.
Installing low voltage landscape lighting is a good do-it-yourself project for most homeowners. However, you can make the job easier and prevent problems down the road by avoiding these errors.
5 Common Landscape Lighting Installation Errors
Digital voltmeter1. Not Using a Voltmeter – The introduction of LED landscape lighting has diminished the need for a voltmeter because there’s now a wider range of acceptable voltage. However, it’s still essential to have this tool on hand for systems that have more than 10 lights or wire runs longer than 100 feet. And it’s a must-have tool for troubleshooting a system.
2. Not Using a Waterproof Direct Burial Splice – Since landscape lighting cable is buried underground, implementing the correct splice is important. Quality direct burial connectors will prevent corroding and electrical resistance.
3. Excessive Voltage Drop – Unlike a 120v current, 12v currents lose voltage over long wire runs or when the wire is loaded with too many lights. Remember the 100/100 rule: use a maximum length of 100 feet of 12 gauge cable per 100 watts of light. And of course, use a voltmeter to check the voltage at the fixture.
4. Installing Lights In the Wrong Place – Lawn maintenance will prove difficult when landscape lighting fixtures are installed throughout your grass. Fertilizer, lawn mowers and weed whackers can all damage the fixtures. Install the landscape lights in beds and use in-ground well lights for the yard. Also, when choosing where to put your spotlights and flood lights, make sure they are hidden. Outdoor lighting generally looks more appealing when the source is unseen.
5. Using Low Quality Fixtures – Purchase moisture-sealed fixtures that will provide long-lasting light in outdoor elements. Choose solid brass or copper fixtures; these will last a lifetime. Aluminum fixtures may be cheaper up front, but they’ll inevitably rust and need to be replaced in a few years. Simply put, you need professional quality fixtures to achieve a professional quality result.
$59.99
Ever have trouble getting lead wire under a sidewalk?
Introducing VOLT®'s Flexible auger drill bit, which features a hole for guiding cable back through and getting those wires under your sidewalk the easiest way possible without damaging the concrete. Start by digging out the grass on the sides on the slab you need to get under and drill the auger bit right under the concrete to the other side, from there you can slip the lead wire through the hole and pull the bit back through, which in turn will also pull your lead wire with it. The auger drill bit fits most standard size power drills and with the flexibility makes this the only solution for keep wires out of sight.
1-Year Warranty
$8.99
Black UV resistant cable ties are easy to use and made for indoor or outdoor use. Self-locking, one-piece, low-profile ties that save space and keep wires organized and in place. Smooth rounded edges will not cut hands or insulation. Screw mount head for holding cable ties in place and out of sight. Pack quantity of 100.
$22.99
Featuring a handle lock for closure and safety. Ergonomic comfort squeeze handle eases hand fatigue and provides non-slip grip. AWG and metric wire sizes ensure you will always have the right tool with you. Wire strippers also have crimp tool built right in.
1-Year Warranty
$14.99
Heavy duty wire strippers feature a handle lock and non-slip comfort grip for safety. AWG and metric wires sizes ensure you have the right tool every time. Heat treated steel pivot bushings and automatic spring return ensure construction quality.
1-Year Warranty
