15% OFF Select Deck, Step & Hardscape Lights with Code DECK15 | SHOP NOW
Landscape Lighting for the Holidays
June 18, 2020 December 7th, 2023 No Comments
By VOLT ® Lighting - June 18, 2020
Installing traditional holiday lighting can be extremely time-consuming – hours can be spent unpacking, untangling and setting up. When the holiday is over, you also have to remove and repack all of the decorations. Not only is this process time-consuming, it is also dangerous when involving ladders and working on rooftops.
A simple way to convert your home for the holidays is to use color-coordinated landscape lighting. Color-changing LED bulbs and color-changing LED lights offer a permanent outdoor lighting solution for holidays, special events and year-round use.
Benefits of Color-Changing LED Landscape Lighting
  • True-to-color LEDs produce powerful, vibrant colors
  • Multiple color combinations including traditional white for year-round use – not just for use during holidays
  • Convenient remote control capabilities available – quick & easy set up
  • Variety of fixtures available for any lighting application
  • Safe, energy-efficient low-voltage (12V)
  • Lifetime Warranty on all VOLT® RGBCW LED Bulbs & RGBW LED Brass Lights
How to Use Color-Changing LED Landscape Lights
When using color-changing landscape lights for holidays specifically, colors should ideally be applied in an alternating manner.
For a Halloween themed design, you can alternate colors between green, purple and/or orange. For a Christmas themed designed, alternate between green and red. Patriotic colors like red, white and blue can also be used for a variety of holidays such as July 4th, Memorial Day or Flag Day.
If using VOLT®’s RGBCW LED bulbs, you can conveniently set up permanent lighting zones that allow for quick & easy adjustments for any occasion.
There is no better way to prepare for holidays or special events than having eye-catching, colorful illumination displayed on your home.
Color-changing LED landscape lights provides a variety of vibrant colors and offers efficiency, durability, and safety. Flexibility with applications and ease of control make them the ideal choice for homeowners looking for a permanent holiday lighting solution that also looks beautiful year round with traditional white light options.
