PROJECT: RGBW Illuminated Home
June 30, 2022
Variety and benefits of the illuminating RGBW light fixtures.
RGBW Lighting
Get inspired with RGBW lighting ideas, tips, and tricks!
No matter the holiday or occasion, homeowners can illuminate their landscape in vibrant colors, thanks to the new series of RGBW LED outdoor lighting fixtures. The new series of RGBW LED outdoor light fixtures provides a wide range of colors to choose from when lighting your home regardless of the occasion or holiday!
RGBW refers to the four standard colors in the LED chips: red, green, blue, and white. Both RGB and RGBW LED lights mix red, green and blue to produce many different colors. However, the dedicated white chips in RGBW LED lights result in a more diverse color palette and can also enhance or raise the brightness of the other colors.
Most importantly, RGBW LED lights can be used as a stand-alone crisp white light. RGB lights must run all three colors at once to produce something that resembles a blurry or foggy white. This uses a lot of energy and does not result in a true white tone, which is why RGBW is better for outdoor lighting.
All RGBW LED outdoor lights are set at 100 percent light output with 2700K color temperature, which is the most commonly used in landscape lighting. Use the VOLT® RGBW Remote Control to unlock the color-changing capabilities and adjust your RGBW LED lights to your preferred color and intensity. The new VOLT® RGBW LED outdoor light fixtures are controlled by one remote, so no more assigning different remotes to each fixture.
The VOLT® RGBW G4 Infiniti™ 60 Integrated LED Brass Spotlight is the flagship product for the new series of RGBW LED outdoor lights. VOLT® currently makes a variety of 12V and 120V RGBW LED spotlights and floodlights for landscape lighting, and more fixtures are coming soon!
This gallery provides various ways to use RGBW lighting within your landscape. RGBW lighting is great for holidays, sporting events, parties, and much more. The great thing about VOLT® RGBW lighting is the option to have a warm (2700k) output option for when there isn’t a party or event going on.
RGBW lights 1
RGBW lights 2
RGBW lights 3
RGBW lights 4
RGBW lights 5
RGBW lights 6
As low as $154.99
Durable cast brass (thick/heavy). Dimmable with adjustable color & CCT (remote control required). Adjustable glare-guard & knuckle for precision aiming.
RGBW RGBW
As low as $119.99
Durable cast brass (thick/heavy). Dimmable & color-changing (remote control required). Adjustable glare-guard & knuckle for precision aiming.
RGBW RGBW
As low as $209.99
Provides powerful, wide light output. Durable, cast brass construction (thick/heavy). Adjustable yoke mount for aiming light output.
RGBW RGBW
As low as $149.99
Durable cast brass (thick/heavy). Dimmable & color-changing (remote control required). Fully-submersible design (IP68 rated).
RGBW RGBW
A step by step guide to set up color changing LED landscaping lights.
How to Set Up VOLT® Color-Changing LED Landscape Lighting Bulbs
Learn how to set up VOLT®'s color-changing LED bulbs. Easily change colors, color temperature, brightness and create multiple lighting zones.
LED Bulbs: Choosing the Best Color Temperature for Outdoor Lighting
Learn how to choose the LED bulb with the right color temperature to create the desired effect in your landscape lighting.
How to Use Dichroic Color Filters for Landscape Lighting
Dichroic filters alter the color of a light source. Learn how to select, care for & use filters to bring your landscape lighting to life.
