Spring Solar Light Sale – 10% OFF! | SHOP NOW
VIDEO | How to Insert Wires in VOLT® Clamp-Connect LED Transformers
June 8, 2020
VOLT® Clamp-Connect LED Transformers for Landscape Lighting
Our Clamp-Connect 12v/15v LED Landscape Lighting Transformers feature easy-to-use Clamp-Connectors – simply flip open to insert wires, then clamp tight to ensure a rock-solid connection. No tools needed. Timer and photocell receptacles allow this professional-grade low voltage transformer to be fully programmed to turn your system on and off as needed.
Why Choose LED Lighting?
Learn about the benefits LEDs provide and why they are rapidly replacing incandescent, halogen, fluorescent and other light sources.
Why Switch to LED Bulbs?
As the quality of LED bulbs has improved and the cost has dropped, LED lighting makes more sense than ever.
Learn about bulb types. LED vs. halogens, brightness, wattage-to-lumen equivalents, beam angle, color temperature and more.
How to Choose Landscape Lighting Wire Connectors
From hub connectors to wire nut connectors to crimp and barrel styles, learn about the types of wire connectors used in landscape lighting.
