Your backyard shouldn't stop at the edge of your lighting. The VOLT® OHM Outdoor Audio System brings real, room-filling sound outside. There is no complicated wiring, no installer required.
If you've already set up your landscape lighting, adding sound is the natural next step. The OHM is plug-and-play, so you can have music playing in your yard the same afternoon you unbox it. It's built for homeowners who actually use their outdoor spaces. Whether that's hosting a backyard cookout or just unwinding after work with the right soundtrack.
Outdoor living isn't a trend. It's how people actually want to spend their time at home. And sound is what makes a space feel alive. Most outdoor speakers are either too complicated to set up or too cheap to sound good. The OHM skips both problems.
The Five Key Benefits of VOLT OHM:
Ease of Installation:
This outdoor audio system is made for DIYers, the system can be installed in under an hour and there is no additional purchase of speaker cable. OHM is prewired, eliminating the need to cut or splice any wiring like competitors. With a stake and mallet cap included, this installation requires zero experience. Like our lighting, DIY is the best choice for homeowners looking to upgrade their outdoor spaces.
Premium Grade Material:
OHM was built with high-quality construction to ensure durability and long-lasting performance. Unlike competitors, OHM is made of ASA material. Designed to perform under any weather conditions while maintaining a sharp finish and color.
Driver and Tweeter Combination:
Each speaker has a 3.5” driver and 0.5” tweeter. These two together create clear highs and deep lows, resulting in a full, clear range of sound. This tweeter is a unique feature that guarantees an unmatched sound performance.
Flexible Mounting Options:
OHM offers various ways for the speaker and subwoofer to be mounted. This flexible mount design can be installed on the ground, surface, deck, or in-ground. The subwoofer can be placed anywhere.
Adjustable Speaker Knuckle:
If you are looking to adjust your speakers however you want, OHM is the right choice for you. Unlike other products with fixed mounting, OHM speakers are able to adjust to 150 degrees. This allows for the reduction of unwanted sound. No matter where the speaker is mounted, the sound performance will be crisp and clear.
System Expandability:
If you have any additional questions, please give us a call at (813) 978-3700 or email us at customersupport@voltlighting.com.
