Same-day shipping on orders placed before 5pm ET
Brass Path Lights (Bronze)
Items 25-38 of 38
Set Descending Direction
    VOLT® Mini Parasol Brass Path & Area Light (Bronze)
    $49.97
    A low profile, angular design that adds beauty and security to any landscape.
    The fixture provides a generous spread of soft-edged illumination that's ideal for all types of paths and landscape features. Various mounting options available. 13" tall for low profile path lighting applications.
    Lifetime Warranty
    Learn More
    VOLT® 12V Estate Monarch Brass Path & Area Light (Bronze)
    $134.97
    Estate size path and area light.
    This Estate Size Path & Area Light is a high-quality outdoor lighting fixture that projects a wide circle of uniform illumination with a 10" diameter shade. The intricate filigree inlay blends best with luxurious and ornate style homes.
    Lifetime Warranty
    Learn More
    VOLT® 12V Estate Ares Brass Path & Area Light (Bronze)
    $129.97
    Lifetime Warranty
    Learn More
    VOLT® 12V Estate Colonial Brass Path & Area Light (Bronze)
    $139.97
    This Estate Size Path & Area Light is a high-quality outdoor lighting fixture that projects a wide circle of uniform illumination with a 9" diameter shade. The straight lines and architectural pattern lends itself to blending with traditional, estate size homes.
    Lifetime Warranty
    Learn More
    VOLT® 12V Estate Sedona Brass Path & Area Light (Bronze)
    $129.97
    Estate size modern-style fixture with durable brass construction.
    This Estate Size Modern Path & Area Light is a high-quality outdoor lighting fixture that projects a wide circle of uniform illumination. Ideal for gardens with Tuscan themes, but also works for properties with modern landscape styles.
    Lifetime Warranty
    Learn More
    VOLT® 12V Estate Stratum Brass Two-Tier Path & Area Light (Bronze)
    $129.97
    Estate size tiered pagoda-like fixture with durable brass construction.
    This Estate Size Two-Tier Path & Area Light is a high-quality outdoor lighting fixture that projects a wide circle of uniform illumination. With a 12" diameter shade, this is the big brother of the 9" Stratum. Both fixtures have clean, modern lines with a traditional pagoda-like shape - ideal for gardens with Asian themes, but also works for properties with landscape structures such as gazebos, pergolas and arbors.
    Lifetime Warranty
    Learn More
    VOLT® Roman Brass Path Light Finial (Bronze)
    $5.97
    Add a designer look to your brass path lights.
    Made from solid cast brass, this heavy duty finial will adds elegance to your brass path lights. The bottom is threaded to screw on the path light hat for a quick and easy installation.
    Lifetime Warranty
    Learn More
  8. VOLT® Max Spread 9" Hat (Brass with Bronze Finish)
    $17.97
    Shade ONLY, does not include lamp housing or finial.
    Solid Brass Construction. Designed to mount on VOLT stems.
    Lifetime Warranty
    Learn More
  9. VOLT® Conehead 7" Hat (Brass with Bronze Finish)
    $17.97
    Lifetime Warranty
    Learn More
    VOLT® Flat Hat 7" Shade (Brass with Bronze Finish)
    $17.97
    Lifetime Warranty
    Learn More
    VOLT® Flat Hat 5" Shade (Brass with Bronze Finish)
    $17.97
    Lifetime Warranty
    Learn More
  12. VOLT® Mushroom 7" Hat (Brass with Bronze Finish)
    $17.97
    Lifetime Warranty
    Learn More
    VOLT® Brass Parasol Hat (Bronze)
    $17.97
    Solid brass construction. Designed to mount on VOLT® path & area stems.
    Lifetime Warranty
    Learn More
Items 25-38 of 38
Page
per page
