- $15.97
Introducing VOLT®'s new line of low voltage LED S8 Wedge Bulbs. This LED light bulb is specifically designed for landscape lighting and outdoor low voltage lighting. These bulbs are fully encapsulated to keep moisture away from the LEDs. Great for applications when you are looking for a cooler light (in comparison to the 2700K).
Lifetime Warranty
Learn More - $15.97
Introducing VOLT®'s new line of low voltage LED S8 Wedge Bulbs. This LED light bulb is specifically designed for landscape lighting and outdoor low voltage lighting. These bulbs are fully encapsulated to keep moisture away from the LEDs. Great for applications when you are looking for a slightly cooler light (in comparison to the 2700K).
Lifetime Warranty
Learn More - $20.97
Designed for use with the VOLT® Wide Splash R7S Flood Light.
VOLT®'s R7S bulbs snap into place utilizing the sockets' spring mechanism and float freely in place. This allows for adjustment which can help aim the light in some applications, or even dim the light depending on the fixture in which they are installed.
The Forever Bulb® - Lifetime Warranty
Learn More - $21.97
Designed for use with VOLT®'s R7S lamp-ready fixtures.
Learn More - $15.97
VOLT®'s line of low voltage LED SCB (single contact bayonet base) bulbs.
This LED light bulb is specifically designed for landscape lighting and outdoor low voltage lighting. These lamps are encapsulated with a milky lens to help keep moisture away from the LED diodes. Great for applications when you are looking for a very warm light, much like candle light.
Lifetime Warranty
Learn More - $15.97
This LED light bulb is specifically designed for landscape lighting and outdoor low voltage lighting. These lamps are encapsulated with a milky lens to help keep moisture away from the LED diodes. Great for applications when you are looking for a warmer light (in comparison to the 3000K).
Lifetime Warranty
Learn More - $15.97
This LED light bulb is specifically designed for landscape lighting and outdoor low voltage lighting. These lamps are encapsulated with a milky lens to help keep moisture away from the LED diodes. Great for applications when you are looking for a cooler light (in comparison to the 2700K).
Lifetime Warranty
Learn More - $15.97
Lifetime Warranty
Learn More - $15.97
Lifetime Warranty
Learn More - $15.97
Lifetime Warranty
Learn More - $16.97
Lifetime Warranty
Learn More - $16.97
Lifetime Warranty
Learn More - $16.97
Lifetime Warranty
Learn More - $16.97
This LED light bulb is specifically designed for landscape lighting and outdoor low voltage lighting. This new version is a higher wattage with a clear lens for brighter illumination. Ideal for applications when you are looking for a very warm, bright light.
Lifetime Warranty
Learn More - $34.97
VOLT®'s LED PAR30 line-voltage (120V) landscape lighting bulb.
The first LED alternative that fits directly into VOLT® fixtures such as the Rotunda Bollard. This bulb coupled with VOLT®’s Rotunda fixture allows for maximum light levels. Fully encapsulated to keep moisture out making these bulbs great alternatives to typical halogen PAR30s.
Lifetime Warranty
Learn More - $1.99
120V G45 LED globe bulb designed to fit VOLT®'s E26 Bistro String Lights.
Replacement LED 120V bulbs for VOLT® E26 Bistro Lights. Consuming only 0.5 watts, these globe bulbs provide the perfect soft low-level light for the Bistro Strings. The warm white color temperature (2200K) provide a pleasant glow that bathes the entire scene in a comfortable illumination.
5-Year Warranty
Learn More - New$19.97
Required for use with VOLT® RGBCW LED bulbs and fixtures
Only one remote required to control all RGBCW devices. Features an RGB color wheel and 2200K – 4000K correlated color temperature, dimming and zoning capabilities with about a 30’ signal range. Requires (2) AAA batteries (not included).
Learn More
