- VOLT® Timer & Photocell Extension Combo
$26.97
Reliable and easy to use timer and photocell combination.
This photocell and mechanical timer combo fits directly into VOLT® transformers and allows for automation of your system without the complexities of programming a digital timer.
1-Year Warranty
Learn More - VOLT® Brass Telescoping Extension Riser (6-12", 12-24", 18-36")$17.97
Available in three different lengths - (6 - 12"), (12 - 24") or (18 - 36").
These telescoping brass extension risers are fully adjustable risers that can adapt with almost all height demands in the landscape. Available in a small 6 inch to 12 inch, medium 12 inch to 24 inch, and a large 18 inch to 36 inch. Also great for increasing stem height of path and area lights to increase illumination area. Match seamlessly with our brass outdoor lighting path and area lights (same material, finish and thickness) 1" Diameter brass pipe with 1/2" NPSM male and female threading.
Lifetime Warranty
Learn More - VOLT® Brass Bronze Extension Riser (6", 12", 24")$9.97
Available in three different lengths - (6", 12", 24").
Brass bronze extension risers are used to raise mounting height of outdoor lighting fixtures above plant material. Also great for increasing stem height of path and area lights to increase illumination area. Match seamlessly with our brass outdoor lighting path and area lights (same material, finish and thickness) 1" diameter brass pipe with 1/2" NPSM male and female threading.
Lifetime Warranty
Learn More - VOLT® Copper Extension Riser (6", 12", 24")$9.97
Copper extension risers are used to raise mounting height of outdoor lighting fixtures above plant material. Also great for increasing stem height of path and area lights to increase illumination area. Match seamlessly with our copper outdoor lighting path and area lights (same material, finish and thickness) 1" Diameter copper with 1/2" NPSM male and female threading.
Lifetime Warranty
Learn More - $16.97
Made for our brass fixtures.
Our brass, estate size riser is used to raise the height of fixtures and add a robust look. These are intended for use with brass spot lights, brass flood lights, and the VOLT® ShadowMaster™ LED path & area light.
Lifetime Warranty
Learn More - $11.97
Made for our "Estate" style fixtures such as our "Coachman"
Our black aluminum estate sized extension risers are used to raise the height of outdoor lighting fixtures above plant material and to increase the illumination area. These match seamlessly with our black aluminum estate sized outdoor lights.
5-Year Warranty
Learn More - $23.97
Lifetime Warranty
Learn More - $39.97
Lifetime Warranty
Learn More - $7.97
Stainless steel mounting plate for 12" VOLT® Hardscape Lights.
Features two stainless steel Phillips screws for attaching to fixture. This bracket is used to slip under capstones, stair treads and other features.
Lifetime Warranty
Learn More - $10.97
Stainless steel mounting plate for 18" VOLT® Hardscape Lights.
Lifetime Warranty
Learn More - $7.97
VOLT® Lanai Mounts feature a slim profile (1.5" x 3" base) ideal for mounting VOLT aluminum spotlights on narrow surfaces such as lanai frames and narrow posts and railings. Cast aluminum construction. (Hardware included.)
1-Year Warranty
Learn More - $8.97
A landscape lighting innovation - designed and engineered exclusively by VOLT™
Our Fixture Canopy Kit allows you to mount a yoke style fixture flush to any flat surface. Each canopy kit features 2 large removable Phillips screw covers for the wire exits. White finish matches the white of our yoke style fixtures.
5-Year Warranty
Learn More - $9.97
Our Fixture Canopy Kit allows you to mount a yoke style fixture flush to any flat surface. Each canopy kit features 2 large removable Phillips screw covers for the wire exits. Bronze finish matches the bronze of our yoke style fixtures.
5-Year Warranty
Learn More - Clearance - While Supplies Last$14.97 $4.97
High performance, compact, and durable.
Heavy duty Cree® LED flashlight with all the features. Its tough aluminum shell keeps the internal components safe, and its Cree® LED is bright and made to last. The convenient wrist strap keeps the flashlight in your hands.
Available while supplies last.
Learn More - $6.97
For use with our Salty Dog MR11 fixtures. Replace the top of the fixture with this glare guard for more glare control while preserving beam spread.
Lifetime Warranty
Learn More - $6.97
For use with our Salty Dog MR11 fixtures. Replace the top of the fixture with this turret top style glare guard for glare control.
Lifetime Warranty
Learn More - $6.97
For use with our Salty Dog MR11 fixtures. Replace the top of the fixture with this grated glare guard to minimize glare from the light source.
Lifetime Warranty
Learn More - $8.97
VOLT® Conductive Electrical Grease is a unique combination of solvents, waxes and corrosion inhibitor system that is designed to penetrate metal pores and dissolve minor corrosion. Great for use on electrical connections, fixture lamp receptacle and fixture threading. Will not cause shorted circuits. Apply the grease during your regularly scheduled maintenance/cleaning of your landscape lighting system. Be sure to apply only a small amount of grease to the fixture or connection, and wipe clean to remove excess grease.
Learn More - $5.97
Stainless steel mounting plate for 3" VOLT® Hardscape Lights.
Lifetime Warranty
Learn More - $6.97
Stainless steel mounting plate for 6" VOLT® Hardscape Lights.
Lifetime Warranty
Learn More - $4.97
A Landscape Lighting Innovation, Designed & Engineered Exclusively by VOLT™
This Lock Nut Wrench is made of tempered steel, which keeps it from bending or warping over time. With its solid and simple design, there aren’t any parts that could possibly wear out. This is most commonly used for adjusting fixture locknuts in the field; it also works well with the locknut on the transformer conduit. It also functions as a normal wrench for use with any 1/2" or 3/4" nut.1-Year Warranty
Learn More - $15.97
Heavy-duty mechanical timer for automated control of your outdoor lighting system.
Use this timer to set ON/OFF times for your VOLT® Multi-tap transformer. Fits neatly inside transformer weather-proof cabinet and plugs directly into the timer receptacle. Use alone or combine with a photocell.
1-Year Warranty
Learn More - $96.97
VOLT's® premium direct burial (DBR) cable is specifically designed for low voltage landscape lighting. The insulation is of high quality polyvinyl chloride (PVC). Sunlight resistant, perfect for outdoor lighting applications.
Learn More - $37.97
Learn More
