- $84.97
VOLT's® premium direct burial (DBR) cable is specifically designed for low voltage landscape lighting. The insulation is of high quality polyvinyl chloride (PVC). Sunlight resistant, perfect for outdoor lighting applications.
Learn More - $179.97
Learn More - $419.97
Learn More - VOLT® Dry-Crimp Pre-Filled Wire Connectors & Housing | Choose 2pk or 12pk$3.97
Dry-Crimp Pre-Filled Wire Connectors are a crimp style wire connector with a copper crimp and protective housing. The protective housing contains a dielectric silicone sealant that will protect and waterproof the splice. Holes in the connector housing seal around the wire to protect silicone from escaping and continuously encapsulating the splice ensuring the connection is secure. Manufacturer approved for direct bury means these are the perfect connector for any outside job.
Choose from 2 pack ($2.97) or 12 pack ($16.97)
Learn More - $3.97
DryConn DBR/Y-600 tubes feature a Red/Yellow Gorilla Nut that eliminates pain and numbness in hands and fingers when creating connections. The comfortable cushion grip make these slip resistant and flexible work skirt protecting again over stripping. Square cut spring provides a secure connection and wire bite with first twist.
Learn More - $3.97
Excellent for making central point connections in low voltage landscape lighting applications. The strain resistant tubes are pre-filled with dielectric silicone sealant that never hardens. Each connector features a secure mechanical connection making them waterproof & corrosion proof. UV and impact resistant. Comes with copper crimp connector.
Learn More - DryConn Black and Grey Waterproof Connectors (Small) | Choose 2pk, 12pk, or 100pk$1.97
DryConn® Black and Grey Waterproof Connectors (use 2 for each fixture) for direct burial connections. This is the most common size connector for landscape lighting applications. Wire cap is filled with silicone to seal and protect raw copper connection from ground moisture - a solid and long-lasting connection.
Learn More
Choose from (2) pack, (12) pack, or (100) pack. - $13.97
Heavy duty wire strippers feature a handle lock and non-slip comfort grip for safety. AWG and metric wires sizes ensure you have the right tool every time. Heat treated steel pivot bushings and automatic spring return ensure construction quality.
1-Year Warranty
Learn More - $21.97
Featuring a handle lock for closure and safety. Ergonomic comfort squeeze handle eases hand fatigue and provides non-slip grip. AWG and metric wire sizes ensure you will always have the right tool with you. Wire strippers also have crimp tool built right in.
1-Year Warranty
Learn More - $39.97
Ratcheting style tool for use with KSC crimp style wire connectors. Pre-defined compression for each connector size guarantees a secure connection every time. Durable build, and color coded for ease of use and dependability.
1-Year Warranty
Learn More - $6.97
Black UV resistant cable ties are easy to use and made for indoor or outdoor use. Self-locking, one-piece, low-profile ties that save space and keep wires organized and in place. Smooth rounded edges will not cut hands or insulation. Screw mount head for holding cable ties in place and out of sight. Pack quantity of 100.
Learn More - $52.97
Ever have trouble getting lead wire under a sidewalk?
Introducing VOLT®'s Flexible auger drill bit, which features a hole for guiding cable back through and getting those wires under your sidewalk the easiest way possible without damaging the concrete. Start by digging out the grass on the sides on the slab you need to get under and drill the auger bit right under the concrete to the other side, from there you can slip the lead wire through the hole and pull the bit back through, which in turn will also pull your lead wire with it. The auger drill bit fits most standard size power drills and with the flexibility makes this the only solution for keep wires out of sight.1-Year Warranty
Learn More - $10.97
For use with our Infiniti™ 30 G3/G4. Replace the glare guard of the fixture with this one for more glare control while preserving beam spread.
Lifetime Warranty
Learn More - $10.97
For use with our Infiniti™ 40 and 60 G3/G4. Replace the glare guard of the fixture with this one for reduced glare while preserving beam spread.
Lifetime Warranty
Learn More - Clearance - While Supplies Last$7.97 $3.97
Designed for use with VOLT®'s Woodsman line of Downlights to help control glare.
This downlight glare guard provides an extra measure of glare control without reducing beam angle. Designed for use with VOLT®'s Woodsman line of Downlights. Heavy duty PVC construction for durability and longevity. Adjustable brass thumb screw with c-clip to prevent it from falling out. Package contains shroud only.
Available while supplies last.
Learn More - $7.97
Designed to provide an extra measure of glare control without reducing beam angle. Made to fit our New Woodsman line of Downlights.
5 Year Warranty
Learn More - $209.97
VOLT's® premium direct burial (DBR) cable is specifically designed for low voltage landscape lighting. 10/2 is a heavier gauge wire, and is primarily for longer runs and/or heavier loads (total wattage). The insulation is of high quality polyvinyl chloride (PVC). Sunlight resistant, perfect for outdoor lighting applications.
Learn More - $417.97
Learn More - $129.97
Learn More - $258.97
Learn More - $41.97
Learn More - DryConn Black and Blue Waterproof Connectors (Large) | Choose 2pk, 12pk, or 50pk$2.49
DryConn® Black and Blue Waterproof Connectors use 2 wire nuts for each fixture when connecting the fixture to the home run when using standard wiring methods. Or if using a hub system, can be used to connect up to (1) #12 with (4) #16 inside the hub. Wire cap is filled with silicone to seal and protect raw copper connection from ground moisture. A solid wire connection solution for landscape lighting applications.
Learn More
Choose from (2) pack, (12) pack, or (50) pack. - $7.97
Ace Connectors™. This is a popular direct burial connector used by the best landscape lighting professionals. It combines the excellent connections made by set screws in a brass cylinder with the waterproof sealing of heat shrink tubing. It also results in a sleek-looking splice, acceptable for wires that exit the ground. Comes with 2 brass connectors, 2 heat shrink tubes, and Hex wrench. Will fit from #12- #18. 2 per pack.
Lifetime Warranty
Learn More - $7.97
Ace Connectors are favorites for many of the most experienced landscape lighting installers. As a brass butt-type connector, the Ace Connector features a compression fitting that uses hex-head set screws to compress the wires. Heat shrink tubing is provided that (with applied heat) shrinks around wires and connectors to provide a water-tight connection. Butt-type connections like these provide a strong, straight streamlined junction that works well for both exposed and buried applications. Comes with 2 brass connectors, 2 heat shrink tubes, & Hex wrench. Will fit wire gauges from #8-#18. 2 per pack.
Lifetime Warranty
Learn More
