Understanding LED Thermal Management
May 14, 2020 April 28th, 2022 No Comments
By VOLT ® Lighting - May 14, 2020
LEDs are known as solid-state technology, which means no glass bulbs, gases, mercury, or filament are in the lamp. Producing LED light is an efficient process of passing electrical energy through solid components, which converts the energy into light. This process creates heat that transfers in the LED itself, components, and the LED mount. The amount of heat produced is a fraction of that emitted by older technologies. However, it is still essential that this transfer occurs both quickly and completely since excess heat will reduce the life of the LED.
One of the main challenges faced by the LED lighting industry is thermal management. An LED that has been exposed to high heat will typically lose efficiency and have diminished light output. For this reason, most LEDs and their accompanying luminaires are equipped with high-performance heat sinks. These are capable of removing the heat generated by LEDs.
Damaging Effects of Excess Heat on LED Lights
  • Temporary Reduction of Light Output – A single occurrence of excess heat – light level will recover when heat is removed.
  • Cumulative Reduction of Light Output – Gradual (but permanent) reduction of light output over time when LED is subjected to multiple occasions of overheating.
  • Color Changes – These result from the gradual degradation of the phosphor layer (responsible for converting LED’s purple color to warm white). Color changes tend to shift towards blue, but may involve off-colors (e.g. green, pink, etc.)
  • Changes to LED Driver Performance – The driver is responsible for changing the incoming AC current to a DC current that flows through the LED chip. Other driver components are responsible for conditioning the current. All these components are heat-sensitive and are subject to damage. Such damage can result in diminished light output, flickering, and catastrophic failure.
Techniques to Better Transfer Heat
  • Internal Transfer Components – All VOLT® LED outdoor lighting fixtures and lamps start transferring heat from where it is generated – at the LED diode. The diode sits on a circuit board or heat sink that draws heat away from the sensitive diode. The heat then travels from these boards and sinks at every contact point.
  • External Heat Sinks – All VOLT®’s LED fixtures have heat sinks in various shapes and configurations designed to provide enough surface area to transfer sufficient heat. These keep the LED’s internal temperature from exceeding its specified limits.
  • Use of Heat Tolerant LEDs – In cases where heat transfer is a challenge (such as with replaceable LED lamps). Engineers utilize LEDs specifically designed to tolerate levels of heat that could generate. In addition, the current that supplies these LEDs is reduced, so less heat is produced.
In conclusion, professionals can trust that VOLT® LED products will perform optimally year after year. This is accomplished through the skilled application of heat transfer strategies – engineered and sourced by the VOLT® Product Development Team.
