The DIY Guide to Deck Lighting
May 27, 2020
A designers guide to improving deck lighting for outdoor beauty after dark
Low voltage landscape lighting is a highly effective and relatively inexpensive way of revitalizing the nightscape of your home, allowing you to enjoy the outdoors after dark. Landscape lighting helps extend the living spaces of your property at night, and sleek, professional-quality fixtures can stealthily enhance the look and feel of your home.
Deck lights, in particular, are compact, versatile fixtures that are highly sought after for a variety of residential applications. Thoughtfully chosen and properly placed deck lightideck lightingng provides bright spots in the landscape while performing a number of tasks that make outdoor living truly great.
Up-Down Deck Light
The Up/Down Deck Light is a distinctive and elegant cast brass fixture that offers the benefits of a compact deck light along with the beauty and functionality of an up/down sconce.
Classic Deck Light
Available with low voltage Bi-Pin LED bulbs. Perfect for mounting on decks, docks, patios, posts, and railings. Professional quality internal components make for a fixture that will last a lifetime, even when exposed to harsh outdoor elements.
Dojo Deck Light
The Dojo’s aesthetic appeal is unmatched by other deck style hardscape lights. Its unique linear design allows light to escape in multiple places while still protecting from glare.
Rotatable Hardscape
Durable, low profile, linear fixtures designed to be easily concealed. Perfect for a variety of applications. They are easy to install, produce an evenly dispersed illumination, and are rotatable 360° for maximum customization.
Techniques
Mounted on posts and positioned on rails, deck lighting helps to illuminate entertainment areas and wash neighboring plants in soft light. Deck lights are also mounted on patios to provide lighting for outdoor seating areas or outdoor kitchens which serves many functional purposes such as a barbecue area on summer evenings.
Some homeowners also find unique ways of applying their deck lights. “Deck lights provide nice, warm light. They provide the perfect amount of gentle light for fire pit evenings – it lets you see your way around the patio but doesn’t overpower the firepit,” Scott from North Carolina claims.
Through the use of deck lights, homeowners can create fully-functioning entertainment areas for their family and guests. The subtle lighting provided by deck lighting also enhances vibrant colors in landscapes and helps create a casual, relaxed mood for your outdoor space.
Lighting For Safety
In addition to using deck lights to illuminate the aesthetic qualities of a landscape, landscape lights can provide security and enhance safety.
When recessed into stair treads and risers, or mounted at defining access points, deck lighting provides safe guidance up steps, signals elevation changes, and defines perimeters within a landscape.
Keeping properties, and the people on them, secure is high on the list of priorities for most homeowners and landscape lighting is a simple and effective way to achieve that.
Technology
In the past, landscape lighting was typically only used to highlight architectural or yard features. With the latest trends, landscape lighting is increasing in popularity due to the benefits provided for outdoor lifestyles.
Modern and edgy designs emerge in neighborhoods every day and trends are evolving. Historically, halogen style fixtures were used and preferred for most landscape lighting projects.
Today, LED is more commonly preferred than its antiquated counterpart. Landscape lights utilizing LEDs offer homeowners the long-lasting efficiency they want, and the powerful light output that they need.
How to Install a Deck Light on a Post
Learn how to install a VOLT® deck light on a post. We'll run the wire down through the post and out the back, then mount the fixture cleanly.
How to Make Low Voltage Wire Connections
Any landscape lighting system needs secure, waterproof wire connections. We'll demonstrate how to make wire connections using wire nuts.
Learn how to install bistro string lights to create a pleasing outdoor space. a
How to Hang Bistro String Lights
Learn how to hang bistro lights and LED string lights. Step-by-step installation walkthrough and design examples for lighting your patio!
A step by step including the tools and supplies needed to install step lights on deck stairs
How to Install Recessed Step Lights on Deck Stairs
VOLT® landscape lighting experts demonstrate how to install a step light on a deck. This easy DIY project requires just a few basic tools.
