How to InstallLearn
How to Install a VOLT® Landscape Lighting Kit
May 2, 2022 May 4th, 2022 No Comments
By VOLT ® Lighting - May 2, 2022
Kit Lights Turning On
In this tutorial, learn how to install a VOLT® landscape lighting kit. Our complete kits have everything you need to install a professional-grade outdoor lighting system!
Landscape lighting is a great addition to any home for a few reasons. It improves curb appeal and provides safety by illuminating paths and walkways. Another important feature is that landscape lighting increases home security.
The amount and type of solid brass fixtures, LED bulbs and the transformer will vary depending on the type of kit. But no matter which kit you choose, installation is an easy, highly-rewarding DIY project. Expansion kits are also available for adding to an existing landscape lighting system.
Before you start, have a general understanding of landscape lighting basics, and have a landscape lighting installation plan for where you will place the LED light fixtures. Additionally, you will want to identify and mark places where there might be irrigation lines or existing cables.
Assemble Parts
Step 1: Assemble Parts
Start by opening the box and assembling the LED landscape light fixtures, wire hubs, and transformer. To install the light bulbs, unscrew the light fixtures’ lenses and push the bulbs into place. After that, attach the ground stakes to the bottoms of the light fixtures and wire hubs.
If you do not want to install the landscape lighting transformer on the wall, you can install it on a transformer pedestal stake mount.
Plan Before Installing Lights
Step 2: Plan
Refer to the landscape lighting guide you made earlier for this step. When installing a low voltage transformer, position it near an electrical outlet and away from any plants that might block the light-sensing photocell timer.
The LED lighting fixtures come with 25 feet of lead wire for convenient use with the included junction hubs. Additional cable is also included for making longer wire runs or extensions if needed. The wire hubs should be no more than 100 feet from the transformer.
Setting the Lights in Place
Step 3: Set the LED Landscape Lighting Fixtures
After placing the fixtures according to your landscape light layout, set the LED light fixtures by driving the stakes into the ground. Using the VOLT® Foot Stomper makes this process a breeze. Once the light fixtures are secure in place, take the time to adjust the angles on the spotlights.
Run the Wires
Step 4: Run the Wires
Start by running the wires from light fixtures to the hub closest to them. After that, run the supply wires from the transformer to each wire hub.
Dig channels along the wires at least 4 inches deep to ensure they stay buried. Take advantage of multiple fixtures in line with a hub and dig one channel for the cables. If you have garden staples, they can be helpful by keeping wires down while burying them.
Connect the Wires
Step 5: Connect the Wires
Insert the wires from the light fixtures into the wire hubs and trim off any excess cable.
Split the cable by pulling it apart 6 inches and strip both ends to expose half an inch of copper. In addition, twist each exposed copper end together to make a solid connection.
Then flip two opposing orange latches on the wire hub and insert one end of the stripped wire on either side. Afterward, flip the orange latches back down to secure the wire. Connect all fixtures to a wire hub and both hubs to the transformer.
Turn on, Test, and Adjust
Step 6: Turn on, Test, and Adjust
Now turn on the transformer and check that all lighting fixtures illuminate. If a light fixture does not turn on, check if the wire has a secure connection to the hub. However, if the problem persists, swap the bulb that you know works.
Don’t worry if the light fixture or bulb is damaged; give us a call, and we’ll get you a new one. Every kit comes with our lifetime warranty.
Enjoy Landscape Lighting
Step 7: Enjoy
Lastly, fine-tune the timer and beam angles, then enjoy coming home to a well-lit house.
Congratulations – you have installed a landscape lighting kit! If you have any questions about how to install a landscape lighting kit or about any VOLT® products, please give us a call at (813) 978-3700.
Check out more How-To Videos for inspiration!
How to Install
How to Install a Deck Light on a Post
In this instructional video, learn how to install a VOLT®…
How-To Videos
Low Voltage Landscape Lighting Transformer Installation
For step-by-step instructions, tips and troubleshooting advice, please see this…
How-to Videos
Installing landscape lighting is an easy DIY project, but it's…
