How to Light Up a Flagpole
December 1, 2025
Flying the American flag at night is a proud tradition, but it comes with one important rule. According to U.S. Code Title 4, Chapter 1, Section 6(a): "It is the universal custom to display the flag only from sunrise to sunset. However, when a patriotic effect is desired, the flag may be displayed 24 hours a day if properly illuminated during the hours of darkness."
Proper flagpole lighting does more than satisfy the U.S. Flag Code. It creates a striking nighttime focal point in your landscape, drawing the eye from the ground, up the pole, and to the flag itself. In this flagpole lighting guide, we cover the best fixtures for lighting a flag, how many lights you need, where to place them, how bright they should be, and which beam spread will keep your flag fully illuminated all night long.
Why You Should Light the Flag and the Flagpole
Lighting the flag alone is not enough. To create a true patriotic display, you also need to illuminate the flagpole. A lit pole provides a visual path that starts at the ground, reaches into the night sky, and ends at the flag. Without it, the flag appears to float in darkness with no connection to your landscape.
The good news is that the pole itself is easy to light. Most flagpoles are white, so they reflect light well and require far less brightness than the flag. A single well placed fixture can handle the pole, while the rest of your lights focus on the flag.
Choosing the Best Fixtures for Flagpole Lighting
What Type of Light Works Best?
Directional lights are the right choice for flag lighting because they produce the narrow beam spreads needed to reach the top of a tall pole. Two types of directional fixtures work well:
  • Spotlights: Brass and copper spotlights can be mounted in turf with ground stakes. For aluminum spotlights, an aluminum flag pole mount lets you attach the fixture directly to the pole.
  • In Grade Lights: If your fixtures need to sit flush in turf or another walkable surface, in grade well lights are often the best choice.
Pro Tip: Never pair an aluminum flag pole mount with a brass spotlight. Aluminum mounting threads will corrode over time when they stay in contact with brass.
How Many Lights Do You Need for a Flagpole?
Plan on at least two fixtures, and ideally three. Multiple lights aimed from different directions ensure the shadow of the pole never obscures the flag as it waves through the night.
Where Should Flagpole Lights Be Placed?
Since you are lighting both the flag and the pole, one fixture should project light onto the pole as close to the ground as possible. Place this fixture within about 1 foot of the pole, or mount it directly on the pole itself. Any additional fixtures can be installed in the most convenient locations at any practical distance, as long as their beams reach the flag.
How Bright Should Flagpole Lighting Be?
Your flag and flagpole should be the brightest objects in your illuminated landscape. The red and blue fields of the American flag absorb a great deal of light, so bright LED output is essential for the flag to stand out against the night sky.
  • Integrated LED Fixtures: Choose a fixture with a light output of at least 300 lumens. For very tall flagpoles, consider the G4 Infiniti™ 40 LED Spotlight, which delivers a bright 500 lumen output and accepts interchangeable optics (sold separately) including 17 and 24 degree beam spreads, the two angles most often needed for flag lighting.
  • Lamp Ready Fixtures: The bulb's light output will be slightly higher than the fixture's, so select LED outdoor bulbs that produce more than 300 lumens. Our 5W MR16 LED bulb is a great choice with a 400 lumen output, equivalent to a 30W halogen.
Remember: With LED bulbs, lumens indicate brightness, not wattage. Halogen equivalents also vary by manufacturer, so always compare lumen output when shopping for LED flagpole lights.
Choosing the Right Beam Spread for Flag Lighting
Use the narrowest beam spread that still covers the flag. A narrow beam concentrates the most light at the top of the pole, where you need it. At the same time, the flag can wave in any direction, so the beam must be wide enough to illuminate the flag no matter where it sits around the pole.
Here is a simple rule: if your flag is 6 feet wide, your beam spread must cover a circle with a radius of 6 feet around the pole. When using multiple fixtures to achieve full coverage, aim them carefully so their beams overlap at the top of the pole.
VOLT Lighting beam angle calculator chart for flag lighting showing 12, 24, and 36 degree beam spreads by flagpole height and flag width
How to Use the Beam Angle Calculator
Move vertically on the chart until you reach your flagpole height. Then move horizontally to the right a distance equal to your flag width. Select the smallest beam angle that encompasses the entire flag. This beam angle can come from a single fixture, or it can be supplied by two or more fixtures with beam angles that add up to the desired angle.
Example: A 6 foot flag on a 35 foot pole requires either one 24 degree spotlight or three 12 degree spotlights. Keep in mind that it takes about three of the 12 degree spots to cover the same circular region as one 24 degree spot.
If you have questions about beam spreads or any other landscape lighting project, give us a call at (813) 978-3700. Our lighting experts are available 7 days a week to help.
Best Spotlights for Flagpole Lighting
VOLT® Top Dog Large brass spotlight with adjustable glare guard illuminated at night
Top Dog Large (Bronze)
Lamp Ready Spotlight | 150 to 500 Lumens | 4.8 Stars (440 Reviews) | From $59.99
Our best selling, heavy duty fixture. Durable cast brass construction that is thick and heavy, with an adjustable glare guard and knuckle for precision aiming at tall flagpoles.
VOLT® G2 Fat Boy brass spotlight illuminated in a landscape
G2 Fat Boy Large (Bronze)
Lamp Ready Spotlight | 150 to 500 Lumens | 4.8 Stars (671 Reviews) | From $39.99
Our most affordable best seller. Economical sheet brass construction with a built in glare guard and adjustable knuckle for aiming light output exactly where you need it.
VOLT® Fat Boy Medium brass spotlight in bronze finish illuminated
Fat Boy Medium (Bronze)
Lamp Ready Spotlight | 150 to 500 Lumens | 4.8 Stars (45 Reviews) | From $39.99
The medium sized version of our most affordable best seller. Economical sheet brass construction with a built in glare guard and adjustable knuckle for precise aiming in tighter spaces.
Light Up Your Flag with Confidence
Shop professional grade flagpole lighting backed by a lifetime warranty and live expert support 7 days a week.
Shop Flagpole Lighting
VOLT® Lighting | Factory Direct | Professional Grade | Lifetime Warranty | Live Expert Support
Waterfront safety
How Waterfront Lighting Increases Safety and Security at Home
Discover how waterfront lighting improves safety and security by increasing visibility, deterring intruders, and reducing hazards around your home.
Improving home safety and visibility with outdoor lighting.
How to Use Landscape Lighting for Better Home Safety
Avoid hazards, deter wildlife, and enhance home safety with landscape lighting. It's easy to install and offers immediate results.
The proper home lighting to increase beauty and utility with outdoor spotlights
Home Lighting: Increasing Beauty & Utility with Outdoor Spotlights
If landscape lighting is painting with light, then spotlights are the brushes. Spotlights are commonly used for emphasis when up-lighting.
How to Select Spotlights for A Landscape Lighting Project
Learn how to choose the best spotlights to call attention to architectural or landscape features around your house.
